Hello everyone
I’m studying how to change PID in flight during a mission with Ardupilot and Mission Planner.
I know the PID tuning procedure through channel 6 but I can not find any command that allows to change the PID through a switch. Imagine that the drone during the flight becomes heavier, it is necessary to change the PID to a value previously tested.
I would therefore like, in flight, to make a switch that changes the PIDs and then continue the mission.
Why not just use the CH6 function but instead of a pot or slider allocate it to a switch.
Setup you min and max rates to the values you want.
If you wanted to change a few PID’s at once you probably could do it with a script and Mavproxy or similar.
But I will echo what @Michael_Oborne tried to tell you, DON’T DO IT.
To illustrate, back in the ‘good old days’ when you had to tune by hand, it was a long and tedious process.
So using a second person on the GCS making changes to the PID settings while flying was the logical way to do it.
Until of course the user made a mistake.
In my case it was forgetting to put in a decimal point so instead of 9.000 going in 9000 went in.
The crash was spectacular, and I believe the hex managed to do 4 or 5 flips from only 10m up before driving itself hard into the ground.
When you make any PID changes you need to carefully test them.
