Hi Everyone,
I want to AUTO RESTART the mission after completing the last waypoint to begin the mission again?
Please let me know how to do this.
Thanks.
Hi Everyone,
Thanks.
I have used “DO_JUMP” to do this before:
https://ardupilot.org/copter/docs/common-mavlink-mission-command-messages-mav_cmd.html#mav-cmd-do-jump
Thanks for the reply.
I have gone through the link. What I understood is
After last waypoint I have to put DO JUMP command and changing WP 2. So that, again it will continue from there to last waypiont and repeat again. Is that rite?
Thanks.
If the vehicle has actually landed after the mission completes then by default it will disarm. To avoid the disarm you’ll need to set MIS_OPTIONS = 4. then add a takeoff command after the RTL or LAND command and/or a do-jump back to the first command (which is probably a takeoff) and then it should work.
For me it SHOULD NOT LAND after last waypoint. It should again restart the mission from the 1st waypoint IN THE AIR only.
Thanks
Will try and let you know.
