However, there’s no servo9 in SERVO_OUTPUT_RAW. Now according to the MAVLINK spec there should be a “port” parameter, but I can’t see that in the Pymavlink spec (but I’m also not sure where to find the latest spec).
Are you using MAVLink2?
Since MAVLink2 extension is starting with servo9_raw.
I just run my SITL firmware and connected to it using MAVProxy.
When I run watch SERVO_OUTPUT_RAW, I got the following:
