It has not been done, but now it supports 32 PWM outputs. Usually our flight control board does not have 32 PWM interfaces, so just find a few PWMs without output ports to output.
You can use get_output_scaled to get the scaled output for functions that are not assigned to pins. (mostly, some places check and donβt bother to calculate if there is no pin assigned)
