Dear every one
multirotor is getting dc power supply from the battery and ESC produces 3-phase Ac to the motor so here is how to reduce the dc emf and ac emf by using the shield. copper shield and aluminum shield .
Typically not needed. Is there a problem you are trying to solve?
Read through this, a lot of the issues are grounding problems, some is inductance.
Where possible use:
- longer wires between the ESC and Motor
- shorter power wires (twisted) between the ESC and the power distribution
@dkemxr
actually made a small drone. so mag was placed externally so I reduced a little bit emf. my question is which shield is good for reducing the ac emf and dc emf . for dc emf am using a copper shield for reducing for dc emf which one is good like copper or aluminum?
