How is Course Over Ground calculated?
is it an instantaneous reading from that exact sub-second only; or is it based on what the plane is doing before and after a given sub-second?
thanks in advance!
Jeff
thanks in advance!
Jeff
To what “Course Over Ground” are you referring? Is it something you see displayed in your Ground Control Station? Or perhaps something from a log? (If that, which log?) Or is it somewhere else?
hi,
thanks for responding.
when i extract data from *.tlog, i select the “mavlink_gps_raw_int_t.cog”.
thanks again
I have not looked this up before, so someone else please correct me if I’m wrong!
From reading the source (the calc_blended_state() method of AP_GPS.cpp) I believe that field records atan2(gps_velocity_east, gps_velocity_north). So that might be enough detail for you: The ground course is the magnetic direction of the GPS velocity.
If you need to know exactly how the GPS velocity is calculated (is it filtered? Is it a simple backwards-difference? What happens to it if the GPS loses or gains satellites, changing it’s position estimate? Does it utilize a GPS’s ability to measure the doppler shift for more accurate velocity measurement?) it seems that probably depends on the specific GPS.
Does that help?
