Hi Guys,
I have a small sailboat, the rudder moving with a linear actuator…
How I can see the degree of the Rudder on the mission planner ?!!
Hi Guys,
You can’t see it in degrees. You can show the PWM signal sent to the Servo by adding a User Item to the HUD. CHxout, x being whatever channel your rudder servo is on.
Thank you Dave regards
Can the pwn be done as a graphic with set range or just a raw number?
Just a raw value. No wat to easily scale the PWM output to a servo angle.
