Hi community.
Is it possible to connect the linear actuator with Cube+ orange. I’m developing a big rover and want to use linear actuator as steering system for the turning of the rover.
What is the possibility to achieve this problem statement.
Thanks in advance.
I think some more information mainly about your linear actuator is needed.
I’m using this linear actuator.
Thanks for response
Yuri_Rage
(Yuri Rage)
April 26, 2024, 4:02am
4
A simple two wire actuator is nearly useless for steering control. You need an actuator that can take servo input and has position feedback.
Thanks @Yuri_Rage
What can be the alternative to the servo motor, as I need high torque steering system for the rover.
Welcome to ServoCity where you can get the parts you need to bring your ideas to life! From servos to switches, from actuators to Actobotics, we work hard to bring you the best components backed by unparalleled technical support
Lots of options using a linear servo. Plugs directly into your flight controller for control. Just need to feed it from the main power supply.
