How much height hexa drone can fly by using hobbywing x6 motor type, with propeller 2388,.
in mountain area. wiht pixhawk orange cube, without payload.
There’s a lot of variables to account for.
Battery voltage,
Air temperature and density,
overall weight,
etc.
Use: https://ecalc.ch/ to figure it out. Might cost you a couple of euro, but it’s far cheaper than buying parts you don’t need or won’t work.
Let’s assume a Hexa with T-Motor U8-150’s on 12S with those props at a take-off weight of 18kg (50% hover throttle). At 3500m it would be at 62% hover throttle all else being equal. You wouldn’t want a hover throttle any higher than that.
This is just one example you can’t scale it. As @Allister says buy a eCalc license (where this data came from)
there is no option for hobbywing x6 motor
Hi, yes i was looking for T motor but unfortunately not available in my country. so there is one option hobbywing x6 which motor is used for agriculture drone.
i am planning to build my drone delivery purpose and i want my drone to be than 2000m above the ground.
will it be possible to get that much higher altitude with the motor and i am planning use skydroid t12 remote controller
I don’t know. Use eCalc and choose a motor that’s close in size and kv and figure it out for yourself based on the components you will use and the take-off weight.
It’s kind of like asking “how far will a car go on a tank of gas”.
Are hobbywing motor which come with inbuilt ESCs compatible with Pixhawk??
I am planning on using Hobbywing X6 Combo with Pixhawk for Agriculture drone.
What does that have to do with how high a Hexacopter can fly. The title of this post.
Any ESC is compatible with a Pixhawk if it accepts the standard protocols (PWM, Dshot, etc). Which of course those do.
