How does it work TRIM RC/SERVO Save?
Hello developers and hobby colleagues. Please explain how the function works:
TRIM RC/SERVO Save - Saves current RC input trim and SERVO output trim for pitch. roll, and yaw in Plane and for Steering in Rover.
Can I use TRIM RC/SERVO Save instead of the automatic SERVO_AUTO_TRIM function? I prefer to do the tune manually.
The manual is missing a complete description of the function TRIM RC/SERVO Save
Manual tune on the RC transmitter is usually not a good idea, it confuses the flight control loops.
Better to use the more tested, more often used, and more robust way: SERVO_AUTO_TRIM
Thanks for the reply!
I am an experienced pilot, my settings for direct flight of the aircraft in manual mode are performed with a mechanical adjustment of the position of the servo drives. Only after such a procedure does my plane receive control from the flight controller.
This method requires one flight in manual mode, it takes time, but I’m in no hurry.
However, manual tune gives a better result than SERVO_AUTO_TRIM
It is obvious that an aircraft that flies directly on its own will be successfully controlled by a flight controller.
However I would like to know how the feature TRIM RC/SERVO Saveworks, when I know it I will come to a decision on the use
