How does ArduPilot use data available from GNSS receivers with IMU's and Barometers?
For some time now there have been GNSS receivers that include processors, IMU’s and barometers. The units with this extra capabilities seem to only be on DroneCan connected GNSS receivers.
I’ve also read that work has been done on ArduPilot targets for some of these units.
But I’ve also read that these GNSS receivers use their sensors and processors along with an Extended Kalman Filter to improve navigation data in case of weak or lapses in GPS signals.
I saw references that suggested that uBlox units can use this data and send certain message types that has this additional navigation data.
The only thing that I came across in ArduPilot about this was a parameter that allows EK3 to use external sensors.
I’m wondering if someone could take a few minutes to explain what the current situation is with ArduPilot regarding these GNSS receivers - and the plans for the future.
Besides curiosity, the main reason for wanting to know more about this is to find out if the extra cost of these enhanced GNSS receivers actually provide better capabilities than simple units with a GPS receiver and a compass alone.
Many Thanks!
No, that extra IMU data is not used yet. I can not comment on any future plans.
Thanks @amilcarlucas.
I need to reach out to the uBlox folks to see what they have to say about their processors using these additional sensors.
If ArduPilot doesn’t use any of this data, I don’t see that there’s an advantage of using something like a Here4 or HerePro. At least not yet.
Queries like this suggest that uBlox has additional message types to report data that includes inputs from the additional sensors.
Of course if ArduPilot doesn’t use these messages, they don’t offer an advantage.
I’m inclined to agree, but it’s a matter of user perspective, of course.
If you prefer the convenient form factor with a CAN connection, the Here4 or HerePro are near direct replacements for legacy Here series hardware and offer significant performance improvement in the GNSS receivers alone.
If you can use bare PCB hardware, there is equal or better performing hardware at a fraction of the cost, and there are alternatives with differing enclosures that may also save on your wallet.
Thanks @Yuri_Rage
The one advantage of the HERE units is the lights. A convivence - like the buzzer.
I’ve been using simple un-cased gps/compass modules on the little quad I’ve been designing, but I’m thinking of making a mount bracket that allows attaching a HERE unit directly to the top dome, so I don’t have to rely on double sided VHB or Nano tape.
As I’m new to CAD, modeling the attachment to a HERE will be an interesting challenge.
Lack of screw holes on those GPS units is criminal oversight. New ones have attachment points for mast mounting but it is overly complicated.
Agreed.
I plan to model after the attachment on the CubePilot iStand, which uses prongs and a single retaining screw.
I’ve found that with proper power wire management, using a mast isn’t necessary. I have an uncased GPS/compass attached directly to the top of a Cube Orange with nano tape and the compass offsets are still tiny.
Here are a couple of reference pics of a Here3+ mast if it helps your modeling endeavors. I’m only guessing that the newer models use the same mounting dimensions (that can be taken directly from the mounting surface).
The CubePilot Website provides a STEP file for those masts . And provides 3D models of their other products
Thanks - I’ve got a couple here on my workbench. I think the last couple of Here3 units I bought came with them.
I’m trying to decide if I want to model the bracket as part of the dome on my frame, or make a bracket that mounts to a flat surface that can be placed in other locations.
If you have other mounting ideas that you think people would find useful, I’d love to have your suggestions.
BTW - in case you haven’t seen it, all the parts and related info for my frame are here: Copter Parts – Download STL Files | Copter Cam Tech
Recommend NOT attaching things directly to the Cube via tape or other mechanical attachment. You might get away with it, but it won’t help the vibration situation.
Thanks @amilcarlucas - that’s really helpful!
I agree - it’s better not to attach anything to the Cube.
This may be why the Y-axis vibes are a little high on the third (non-isolated) imu. I’ve been keeping an eye on them.
I created a STEP file (and STL too) of the top part of the iStand mount - that can be either just glued directly onto a frame part - or grafted on to a part in CAD.
If anyone things these might be useful, I’ll upload them onto my website.
