Acro_rp_p for pitch and roll. Acro_yaw_p for yaw. This assumes that old version of Arducopter has those parameters. Maybe with different names. Not in front of my antique 2.8 bencher or I could say.
RC_Feel:
0 Very Soft
25 Soft
50 Medium
75 Crisp
100 Very Crisp
Is almost equivalent to :
ATC_INPUT_TC:
0.5 Very Soft
0.2 Soft
0.15 Meduim
0.1 Crisp
0.05 Very Crisp
The reason for the code change was the original RC_Feel parameter calculated the time constant using the formulae
input_tc = 1 / (2.0 + rc_feel_rp / 10.0)
As you can see rc_feel is an arbitrary variable with no meaning tangible meaning. Input time constant on the other hand has a clear engineering meaning that can be easily related to and explained. It is the time in seconds that the aircraft will take to reach 63.2% of the pilots commanded rotational acceleration.
