type watch global_position_int on SITL. It will show GLOBAL_POSITION_INT mavlink message.
And what I don’t understand is - why are you setting SIM_GPS_DISABLE to 1?
“simpos” comes from the mavlink SIMSTATE message, which is the simulated vehicle position (as opposed to GLOBAL_POSITION_INT, which is the vehicle’s best guess as to where it is).
They come up in different colored aircraft, left as an exercise to the reader to memorise which is which
In your answer, you mentioned two positional values(SIMSTATE and GLOBAL_POSITION_INT).
You said GLOBAL_POSITION_INT is vehicle’s best guess position, so I cannot get simulated position using watch global_position_int, is it right?
