Assuming that you are referring to the situation where Q_ASSIST is turned on, the first place you would look at is in quadplane.cpp
to find out where Q_ASSIST is being activated.
(I will use Ardupilot’s Master branch as an example, but the basic flow shouldn’t change much across Plane 3.9 - 4.0. Also, I hope I didn’t misinterpret your question
Line 1425 (Quadplane::assistance_needed
) is called to check if Q_ASSIST needs to be activated.
Searching within the same file to find where the above function is called, we see that it is called in Line 1553 of Quadplane::update_transition
if (have_airspeed &&
assistance_needed(aspeed) &&
!is_tailsitter() &&
hal.util->get_soft_armed() &&
((plane.auto_throttle_mode && !plane.throttle_suppressed) ||
plane.get_throttle_input()>0 ||
plane.is_flying())) {
// the quad should provide some assistance to the plane
if (transition_state != TRANSITION_AIRSPEED_WAIT) {
gcs().send_text(MAV_SEVERITY_INFO, "Transition started airspeed %.1f", (double)aspeed);
transition_state = TRANSITION_AIRSPEED_WAIT;
This block of code tells us that when Q_ASSIST is activated, the aircraft switches into TRANSITION_AIRSPEED_WAIT
, which is handled in the same function at Line 1610.
The function then calls hold_hover
at Line 1632. The function itself is given at Line 1007:
hold hover with target climb rate
void QuadPlane::hold_hover(float target_climb_rate)
// motors use full range
motors->set_desired_spool_state(AP_Motors::DesiredSpoolState::THROTTLE_UNLIMITED);
// initialize vertical speeds and acceleration
pos_control->set_max_speed_z(-pilot_velocity_z_max, pilot_velocity_z_max);
pos_control->set_max_accel_z(pilot_accel_z);
// call attitude controller
multicopter_attitude_rate_update(get_desired_yaw_rate_cds());
// call position controller
pos_control->set_alt_target_from_climb_rate_ff(target_climb_rate, plane.G_Dt, false);
run_z_controller();
From here, we should be able to get a sensing that during Q_ASSIST, the autopilot is updating the attitude controller with rate inputs (in fact, if you look deeper, you will be able to find the rate inputs for roll and pitch), and only updates the position Z controller and not the XY controller. Which makes sense, because in FBWA mode + Q_ASSIST, you aren’t focused on holding position and more about maintaining altitude.
If you want to go deeper to find out where the gains are taken from, look into each function in hold_hover
, it will take you to the Arducopter Attitude and Position control libraries.
Quadplane inherits a lot of code from Arducopter, so it jumps a lot between the Plane and Copter libraries. But quadplane.cpp
should usually be the first place you’ll want to look at
Hope this helps
