pmshop
(pmshop)
1
On previous versions of Mission Planner, the map would “focus” on the home point set when a saved waypoint mission was loaded.
Now, the map stays in the previous home point area when a saved waypoint mission is loaded with a different home point.
Ver 1.3.56 build 1.3.6672.30243
are you loading from a drone? or from a file? just want to confirm
pmshop
(pmshop)
3
From a file.
Used to focus on home after loading.
cool, I found the issue. will be fixed in the next beta
pmshop
(pmshop)
5
Thank you sir.
I appreciate the efforts!
