Holybro H-RTK F9P base station
Hi there,
has somebody set up Holybro H-RTK F9P as base station?
Thanks
I’m still struggeling to get the H-RTK F9P running with MissionPlanner. Can someone help?
use this manual, is very simple:
http://www.holybro.com/manual/Holybro_H-RTK_M8P&F9P_GNSS_Manual.pdf
Thanks!
do you have the H-RTK running?
yes, only I Have a m8p version, but
I just followed the guide that I put you above and it worked
with the F9P I don’t see any sattelite bars in MP so I’m wondering.
Despite that in u-center the module is running…
do you have the base station well connected to the pc? is it the correct port? the correct baudrates? you have the drivers (in case the pc does not recognize you device)
That how far I can get in MP:
baudrate 38400 like in u-center
Link Status
Input date rate: xxxbps updating
Messages seen: NMEA=xxx
but that’s it :confused:
