ADIR
(ADIR BEN AVI)
September 22, 2022, 10:56am
1
hi everyone, I have to figure out how to set my f9p by holybro to the cube black…
I tried the recommendation by holybro and I set it up to the GPS 2 port with 6 pin connector and the mission planner not recognizing the GPS (no hdop and sat)
vdd
rx
tx
scl
sda
gnd
is there someone with experience with this combination?
I am not sure if the F9P is supported by ArduCopter 4.0.x
xfacta
(Shawn)
September 22, 2022, 10:02pm
3
Check your GPS_TYPE2 parameter, try 1 or 2
ADIR
(ADIR BEN AVI)
September 28, 2022, 8:26am
4
I think holybro put information about cube and f9p … this should work together
They work fine together in ArduCopter 4.2.3 version, yes.
I have them here and can verfy it.
ADIR
(ADIR BEN AVI)
September 28, 2022, 11:34am
6
I put 4.2.3 and also its doesn’t work
Then you are doing something wrong. Are you crossing the tx-rx lines?
What are your parameters?
ADIR
(ADIR BEN AVI)
September 29, 2022, 7:00am
8
yes I cross the TX RX the parameter is set for gps_type2
Do you have any idea?
champ8242
(Bart Zondag)
September 29, 2022, 7:32am
9
Have my H-RTK F9P Helical running fine on the cube Black as well running on the Orange. So it should work with standard supplied cable
ADIR
(ADIR BEN AVI)
September 29, 2022, 10:43am
10
can you give your parameters for that ? and which port you use
champ8242
(Bart Zondag)
September 29, 2022, 11:38am
11
Port = GPS2 = Serial4
SERIAL4_BAUD = 38
SERIAL4_PROTOCOL = 5
GPS_TYPE = 1
Be sure there is only 1 SERIALx_PROTOCOL with the value of 5
Like I wrote, this works for me with the standard Holybro F9P
