Hi guys.
I am waiting for my new quad to be delivered but am unsure which firmware to install.
hobbyking.co.uk/hobbyking/st … KIT.html
I did a search but cannot find the correct answer.
It is not an ‘H’. According to the pictorial references an H copter has parallel arms either front to back or side to side.
It also does not look like a normal X copter as the arm angles do not bisect at the central point.
Does anyone else fly this quad? If so what configuration did you use?
Thank you.
Mark.
