Setup For V3 Glass Fiber Hexacopter Frame 500mm - Integrated PCB Version
HKPilot Mega 2.7 Flight Controller
Mission Planner will not Install the Firmware in windows 7 for the ArduCopter v.3.2 Hexa when slated for the ArduCopter v.3.2 Hexa.
Faild to download new firmwear:System.UnauthorizedAccessException:Access to the path C:\Program\ Files (x86) Mission Planner\firmware.hex’is denied.at System.IO._Error.WinlOError(int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, int32 rights,Boolean useRights,FileShare share,int32 bufferSize FileOptions options SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy Boolean useLomgPath, Boolean checkHost) at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) at System.IO.FileStream…ctor(String path, FileMode mode) at MissionPlanner.Utilities.Firmware.update(Sting compot, software temp, String historyhash) in c:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\Utilities\Firmware.cs:line 52
