Trying to diagnose an issue here. I’m using multistar 10c 4s 6600mah batteries. My copter has sunnysky v3508 700kv motors with 12x6 props. Ecalc says I should only be pulling 17.75amps at hover.
Today 2 min into a flight with a fully charged battery I hit the battery failsafe. But I’m not sure if it was a voltage failsafe or a mah failsafe, is it possible to tell from the logs? Looking at mission planner after I realized I may have had my battery capacity set wrong. I now think youre supposed to set how much mah you want remaining when the failsafe triggers. So if I want 20% of my 6600mah when it hits failsafe I set it for 1320. I had it set near the capacity of my battery, mine was set at 5500mah, I was thinking warn me when i’ve used 5500mah of my battery. So i’m wondering if this is why my failsafe triggered, because after two minutes i was down to 5500mah left?
