Many industrial uav have more loading capacity, so the module with strong power supply capacity, support wide voltage input (at least 50V), high current output, 12V 10A, we use TPS54560, the module is very light, but in the use of the process found that the module heating is very serious, you have any better recommendation?
Mauch products are good.
I use a lot of the TDK lambda i3A modules 9-53V input. 5-28v output at atleast 8A. 11g. They also have other even more powerful modules. Very power dense.
Although no matter what you use you will probably want to use some active cooling.
tks ,i will check it .
