Does anyone have suggestions for how to monitor a 48V (nom), 110Ah AGM battery stack that may produce up to 200A continuous current? This is for a build using Cube Orange.
I did see one solution from Mauch, are there others?
Thank you!
Thank you!
Mauch is pretty much the best battery monitoring setup for that scale of aircraft. I use the Kore Carrier Board in a lot of my builds - but they are only capable of doing 140A continuous.
Thanks for your reply.
