Hi y’all.
I have designed an hexarotor equipped with
tarot 4108 motors
tekko 32 ESCs
pixhawk4
I am using the 4.0.7 version of the firmware and I totally not able to get the ESC telemetry.
The parameters are configured following the wiki guide and I am using Dshot protocol - all the telemetry wires are connected together in serial4/uart4.
From the HWdef page for the Pixhawk 4: The remaining 8 outputs (labelled AUX1 to AUX8) are the “auxiliary” outputs. These are directly attached to the STM32F765 and support all PWM protocols. The first 4 of the auxiliary PWM outputs support DShot.
Sure, there are other Flight Controllers that will do that. If there was any hope of it working try this and then see what the Banner message says for channel output protocol. Probably the same.
