Hexacopter with propeller protectors cause motors imbalance
Hello there,
I’m flying an Aurelia X6 Standard with the Copter-4.5.2 firmware.
The drone behaves normally with the stock hardware as shown in this log file.
I do get the following message, but from what i could read about it, it seems to be a harmless behavior.
EKF3 IMUX MAG0 in-flight yaw alignment complete
Also, MAG1 seems to be greatly affected by the motors’ noise, but it doesn’t seem to affect the drone’s behavior.
I’m trying to remove the stock landing gear and add prop protectors, but I get very strange behaviors when i do so, as shown in this log file.
The prop protectors weigh about 200g each for a total of 1200g, which is well below the drone’s payload limit of 5000g. From what I can tell, they have 2 main effects on the drone: they increase its inertia, and they guide the prop’s flow straight down like a fixed rudder. I know that the yaw is not tuned properly for the added inertia, but I can’t explain the observed behaviors with this alone.
The issue is that the drone sometimes starts spiraling without any yaw input from the controller.
The desired yaw seems to follow the actual yaw when the spiral is observed, I do not understand how this is possible. Also, the desired yaw rate doesn’t seem to have much of an impact on the output yaw rate while the spiral is occuring.
The Aurelia X6 uses a FRAME_CLASS Hexa and a FRAME_TYPE X, which corresponds to the image below:
This leads to the most unexplainable behavior. The RCOut seems to show that the motors are controlled in 2 different groups (1, 3, 5 and 2, 4, 6), this doesn’t seem to make any sense considering that both groups have CW and CCW motors. Also, since both groups are on different sides of the drone and that their inputs have such a huge difference, the drone should be performing flips, but yet, it is only spiraling in yaw.
Here are the possible causes that I have already looked at:
Wrong motor mapping:
I took out the drone’s props to make sure that the motors were mapped properly and they do match the HEXA X image shown previously.
Center of mass imbalance:
I can balance the drone along the axis between the two motor groups (between motors 5 and 6) withtout any problem.
Motor/ESC 5 or 6 failure:
As soon as I use the stock landing gear, the issue disappears, which eliminates this possiblity.
I’m all out of ideas to explain the 2 motor groups behavior. If anyone could help me figure out this issue, it would be greatly appreciated.
Do you have a photo of the protectors? Are they adding significant weight (I’m guessing not but who knows)?
Here’s a picture:
As I said, they weigh about 200g each for a total of 1200g (6x).
This video about adding a camera reminded me of this thread.
I think you’re having some of the same problems Pawel had. Even though the weight is within limits, the inertia is greatly increased by adding the weight so far from the center of the hexacopter… If you’re determined to keep the protectors, I think you need to make them much stiffer. You might want to brace between the arms so they can’t move as much as they presently move.
Good luck.
I just wanted to provide a quick update for anyone who might encounter a similar issue in the future.
I finally discovered that motor 6 was slightly defective from the factory. When I spun the motors by hand, I noticed that this motor offered more resistance than the others. Initially, I mentioned that the drone behaved normally with the stock hardware, but after reviewing the log files more carefully, I realized that the two motor groups were already visible, although they were less apparent compared to when I added my own hardware.
This explains why the drone didn’t flip over despite the strange logs. Motor 6 wasn’t spinning at the expected speed, so motors 2 and 4 had to overcompensate, while motors 1, 3, and 5 couldn’t exert too much force to counterbalance them and stabilize the drone.
that adds like 12+ new harmonics, buy a cheap heli and learn to fly better first. sorry no other/nicer way to put it
imo
