Hexacopter Unable to withstand nominal wind conditions
I’ve a hexacopter with enough thrust to weight ratio (2.8:1), but it fails to sustain 3-4 m/s wind.
Observations :
  1. Motors are tilted by 2-3 degrees in X axis, I was able to align those in U axis but I failed at X axis .
  2. All motors are working on different PWM values.
  3. Some jerks/oscillations observed visually while flying.
Looking for suggestions to make it fkt stably.
Also need guide on tuning PIDs? Will it resolve my issue or not? If yes how and if not why?
Open to discuss things in detail.
Seeking for support.
Processing: 2024-08-14 14-32-03.bin…
Use this guide to solve it. Lots of both how and why inside it.
If you want support for that log post a proper link to it.
Hi @dkemxr
Here are the log files of the flight I took.
https://xcaliberinfotech-my.sharepoint.com/:u:/g/personal/sgawali_phoenix_tech/Eb90YreF7WVJm_WFJk92NKgBJblbMLElxkzI2kkigt2o9Q?e=korQeX
https://xcaliberinfotech-my.sharepoint.com/:u:/g/personal/sgawali_phoenix_tech/EcaV-MUHDv9KtMqegLgcXOIBxpsgu75VxELO3tSgr7i9fQ?e=uAyQFs
https://xcaliberinfotech-my.sharepoint.com/:u:/g/personal/sgawali_phoenix_tech/EUKgyzRoLTtOtYeKRpFnqacBzm3xbhqNVXR4ZHP8VraHaQ?e=ZjC71i
Thank you @amilcarlucas, will try and update it here.
Hello Dave,
Did You got some free time to go through my logs ???
@amilcarlucas Such a interesting and comprehensive tool. Kudos …!!
Update…!!!
Gone throughs @amilcarlucas application, its such a incredible tool, lots of learning.
Did some manual tunning and vehicle is now withstanding as per my expectations.
Thank You…!!!
Can you post your ArduPilot methodic configuration vehicle directory configuration files?
Can I add them as a template to the software to help future users, like it helped you?
Surely, I need some guidance to share those files. Can you please mention which files do you need and were can find them…
When you used the ArduPilot methodic configurator software you created a directory with the name of your vehicle that contains all the files I need. Zip that directory and post it here.
Hello @amilcarlucas
ZD850.zip (383.5 KB)
