Hmm I will check this. I’m using the DMR 30/40, what kind are you using?
Yeah I’ve used the mission planner motor test to verify motor assignment and everything is wired correctly.
I’m using Phoenix Edge Lite 50. I haven’t used the DMR 30/40 before but it looks like you can program them with the Castle software. For my setup, the ESCs defaulted to “airplane” mode which produced a signal at a lower frequency than required for multirotors. I don’t know if the DMRs are the same - but it would be a quick check.
Sorry @steve220 but that goes against all recommendations and against common sense.
Please do continue to do that yourself, but do not recommend that to others. You are endangering their property.
I am just trying to help
Good luck guys
