Flight controller: Cube Orange plus with vibration damper.
Process so far: Initial Parameter -Harmonic Notch Filter-Quick tune (Done)
I am facing some issues listed below
1.If i give pitch forward command after the drone take off it goes slightly left side without roll input.
2.But if we give some yaw command to correct the position then it will learn and move straightly.
After the calibration with Mini TOW the 1st path is going straight way without any heading deviation but in Maxi TOW the 1st path heading is changing as picture attached for your reference in 1st post.
