I am interested in the Herelink system.
I would like to know if there is a solution to connect a camera with an analog output to Herelink Air Unit?
no , it only has dual hdmi inputs
if you have space in your system you could add a ntsc to hdmi converter
Thank you for your reply.
I want to use the system that a small quadcopter, a converter HDMI is too big for my device.
I wanted to be able to use a small FPV camera.
I did not find a small camera that could work with the Herelink.
Yes, and the converter has a long latency (0.5 to 1 sec), I triede it with Lightbridge from DJI
