Power via this plug is only for the USB subsystem. Power via the other cable is still required
Hello Everyone, I wanted to update the firmware of my here+ ground module. I opened up the module only to find out that there is no USB port attached. I am surprised that no one has experienced the same . Should i point out this as a defect to the manufactures .?
And what is the solution for this.?
Thanks in advance
Could you Post a picture of the Module and the place where the connector should be
Your here+ ground module comes with a JST connector for connecting to the supplied USB cable.
not sure what else you are expecting.
the answer to this is the baudrate must be set to the same as it is configured in ardupilot. ie if the autopilot has it as 57600, then the ublox config tool needs to be set to 57600 as well
I believe this is what @nidhirajr was referring to.
So it seems that those of us without the port can’t update the drivers at least without using the serial passthrough. At this point is that an option?
Thanks
