Here + RTK Base as the drone's primary GPS
Is it possible to use the Here+ RTK Base as the GPS onboard the drone instead of being on the ground? Doing my own research, it seems to be the same hardware as the vehicle units. The external SMA antenna option is what’s appealing for my particular drone electronics enclosure needs. Thanks in advance!
https://irlock.com/products/here-base-m8p
yes it works fine on the rover.
