Hi All
I have come to very strange problem.
I have a newly purchased Pixhawk2.1 . I connect Here GPS t PH2.1 . Result: No LEDs , No GPS.
I measure voltage with DMM on the GPS1 Port. There is only 1V output .
Do anyone also have this problem ??
Hi All
No . I power the GPS from UBEC .
Hi Robert,
Could you please share your pinout for powering GPS from a ubec? I am facing the exact same issue. Even the safety switch is not lighting up.
Thanks
Sandeep
You can use the above pinout diagram to power the GPS.
For GPS1: Use Pin1 for Vcc(Ubec +5V) and Pin8 for GND(Ubec GND)
Thanks this is helpful!
