I have a Here+ RTK base. Normally it is connected via the included USB cable, but I saw that the base module also has three pins RX/TX/GND.
Is it possible to set up the communication with Mission Planner (which is normally happening via USB) so that it can instead be accomplished via a Sik radio modem?
If so,
- Is there anything I should pay particular attention to, any settings that need to be changed?
- How should it be powered?
- What are the recommended connection parameters, particularly baud rate?
I figured I’d rather ask before breaking anything or before going down a rabbit trail.
Thank you in advance for your insights!
