I’ve been looking at the SR parameters and have a bunch of questions on what each of these categories contain. If any Pixhawk user has any idea that would help a lot because the documentation is lacking. Thank you.
Raw sensor stream rate (SR0_RAW_SENS) What is this? Pitch and Roll?
Extended status stream rate to ground station (SR0_EXT_STAT) What is extended status?
RC Channel stream rate to ground station (SR0_RC_CHAN) I’m guessing this is just a mirror of the PPM input to the Pixhawk?
Raw Control stream rate to ground station (SR0_RAW_CTRL) How is this any different from the above?
Position stream rate to ground station (SR0_POSITION) I’m guessing this is GPS coordinates? Does it include anything else?
Extra data type 1 stream rate to ground station (SR0_EXTRA1) What in the world is a “type 1 data” or type 2 or 3 for that matter?
Extra data type 2 stream rate to ground station (SR0_EXTRA2)
Extra data type 3 stream rate to ground station (SR0_EXTRA3
Parameter stream rate to ground station (SR0_PARAMS) What parameters?
I have looked at that wiki page before posting. On the page there is a take off the parameters and an unhelpful description. For example, the page says
SR0_EXTRA1 = telemetry stream rage of type 1 extra data.
What the heck is “type one data” it could mean anything and is very vague.
What the heck is “type one data” it could mean anything and is very vague.[/quote]
I’ll figure out which messages are in which groups and get back to you. Thanks.
