Help with 'MAV Errors'?
I see status ‘MAV Errors’ when running Copter in the SITL.
How can I find out more detail what these are?
The “MAV Errors” is the number of corrupted or unreadable MAVLink messages received.
Use the --show-errors option when starting MAVProxy to display more details about the corruption.
Thanks. How is this statement invoked while in the SITL, or do I need to execute a separate mavproxy.py command? I tried adding it to the sim_vehicle.py statement but no luck. Or is there a command to use once in the SITL?
I tried adding it to a mavproxy.py statement but had a link down issue which I haven’t figured out as it used to work.
Use: sim_vehicle.py --mavproxy-arg="--show-errors"
I used it and it executed ok, but then how do I see the 12 errors it was reporting? Is it supposed to be in a list? thx
The errors will appear in the console as they are found:
Many thanks Stephen. Always learning from your help.
btw, I tried searching --mavproxy-arg=" to see how else it can be used to reveal information, but didn’t find much. Is there more that it can be used for?
The --mavproxy-arg="xxx" can be used to pass arguments directly to MAVProxy. Full list at Startup Options — MAVProxy documentation
