Using ELRS as the RC input.
Connected to RX6/Tx6 on Matek H743 wing.
The RC connection shows in the Setup Radio calibration window, but it is really slow and jerky. It acts like its only updating once a second or so
With servos connected in manual mode its is also really jerky…
To try and fix this I set:
First of all, normally the response of ELRS is as instant as remote control can be, whatever the data frequency.
Second, ELRS loves DMA-enabled UARTs. If I remember correctly, Rx6/Tx6 on Matek H743 boards is not DMA-enabled. With me, however, ELRS works just about right even on non-DMA ports, but it has been known to cause problems in the past.
I recall someone having the same symptoms, but so far I cannot remember the exact cause. If I eventually find this out, I will post it here.
