I’m having a couple of issues, and a bit lost in the selection and use of the web based diagnostic tools.
Problem 1: Unhealthy GPS - I have 29 satellites on both GPS’s, NTRIP alive, HDOPs of .5 (on average), clear view of the sky, and haven’t run the methodic configurator (still figuring out the install - had a breakthrough today, but FC is 20min drive).
Ask 1: Is there a plot setup in particular, or a preset that can illuminate what is causing the Unhealthy GPS flag?
Problem 2: With no configuration changes, now getting a prearm error of GPS2 yaw not available when I arm. Can still move in manual with RC xmitter.
Hey Stephen - first, thanks for your contributions as a developer!
My radios are simpleRTK2B Budget ( u-blox ZED-F9P ) set up per the GPS yaw notes from @Yuri_Rage and others.
How can you determine from the chart the degradation? Is a “6” rtk-fixed, and a “5” rtk-float? If you can point me to any docs that explain, much appreciated. Trying not to take valuable time from ya’ll, but didn’t find in my searches…cd
