Hi
I have done a autotuned over the weekend after a complete rebuild of my drone. All went well and fly’s great again! I have change a lot of setting to get it as perfect as possible, would like to get as good as I can get it with the help of you guys that have more experience in tuning. Attached is my log file, PID Tune and Parameters.
My setup:
4 x 3508-580kv
4 x Racerstar RS30A Blheli_S
1355 Carbon Propellers
480mm Cross Motor Dimension
FC Radiolink Mini Pix V1.0ii Firmware 4.0.3
8500mah 4S Lipo Battery
Weight is with battery 2.3kg
Skydroid T10 Remote
Parameter List 04-07-2020.param (17.5 KB)
https://www.dropbox.com/s/dledrebjom6dv6s/2020-07-04%2011-00-43.zip?dl=0(upload://kQqHbfiMMAnjT8y34WJNwRTxJXC.param) (17.5 KB)
vosair
(vosair )
July 7, 2020, 5:26pm
2
If you haven’t already followed this wiki , that’d be the next step I took. There’s a very active thread on tuning it.
hosein_gh
(Hosein Ghanbari)
July 8, 2020, 9:32am
3
your Roll PIDs are very low for a copter in this size
could you upload a log with at the least 1min hover ?
I will make one this afternoon, I’m not home at the moment.
hosein_gh
(Hosein Ghanbari)
July 8, 2020, 4:55pm
6
OK , you have noise problem
looking at your DesPitch, Pitch and DesRoll, Roll you can see noise on gyroscope
and RATE values show it better
to resolve this problem first check for hard wires or anything cloud transfer vibration from body to FC because your vibration is a little bit high
second check for twisted arms your CCW motors are working harder
after all revert back PID values to default and do
harmonic notch filtering then run autotune again
Good Luck to finishing this config
Filters at zero are a bit strange
vosair
(vosair )
July 8, 2020, 5:40pm
8
Yes I should have clarified as hosein did that you need to set up the notch filters, and then do another autotune.
Thanks, we have some heavy rain for the 2 days to come will do the tuning over the weekend and post the results when I’m done.
vosair
(vosair )
July 8, 2020, 11:42pm
10
How is your flight controller mounted to your frame? Might be a good idea to try some of this or something similar.
Hi Vosair
I have installed it in a 3d printed box and stick it to the lid with thick double sided tape.
Vida29er
(Henk)
July 12, 2020, 1:14pm
12
Ok so here is my new tune. it was a little windy this morning.
Shared with Dropbox
i still think that those FILT at zero are strange.
hosein_gh
(Hosein Ghanbari)
July 12, 2020, 4:12pm
14
again low PIDs on roll and its a poor tune
you can see this poor tune and noise on RATE values
also still you didn’t physically balance your copter
with this RCOUT values you will never get an good autotune result
first physically balance your copter
then complete tuning process instruction (every step is important)
and finally configure harmonic notch filtering
