On Mission Planer boot up, I get this Baud Rate pop up, that normally shows when try to connect to FC if the rate is wrong. Any ideas on this? Nothing is connected to USB.
Delete your config file from the Documents/Mission Planner folder. Some bad values got stored there…
Eosbandi, awesome man! Solved and thank you very much!
