I could use a bit of Help here, actually probably a lot of Help. For the past 3 days I’ve been trying to do a Auto Tune on my 690 Hexacopter and trying to get the Tune saved.
At first I had one of the flight modes set up with a 6 position switch on my Horus x10s Express and took off in Stabilize mode switched over to Position Hold mode. Once I got the copter where I wanted it I switch to Auto Tune mode. After about 10 minutes or so I started getting critical Low battery alarms so I landed it still in Auto Tune and disarmed hoping that I would be able to save any of the Tune’s that may have been completed. Went inside and checked the results in Mission Planner and they were all the same as when I started. Checked out a ton of posts here on the Forum and found quit a few posts stating that I should have a separate 2 position switch for High and Low for Auto Tune on channel 7 instead, so that is what I did.
Attempt #2 I pretty much repeated what I did before but this time using the 2 position switch to activate Auto Tune. I also adjusted my Battery Fail safe values to what I thought I could complete a Tune without getting any Fail safe actions that would result in a Auto Tune abort / RTH condition. Apparently it wasn’t set low enough cause after getting a critical Low Battery alert and just before a RTH action I landed the craft ‘Still’ in Auto Tune to disarm it but just as it touched down one of the ends of the landing gear made contact with a small but big enough rock that cause it to tip over. Luckily no damage but Mission Planner was still showing the default PID’s nothing changed any.
Third day, third attempt. Lowered the Battery alarm values some more if I’m not mistaken and removed the onboard compass setting cause I thought I saw a Mag field fault watching the Mission Planner Yaapu Telemetry on the screen of the Horus radio. After deleting the onboard compass I probably should’ve performed another compass calibration but I didn’t cause I thought I saw the same warning after trying this last Auto Tune attempt. Haven’t figured out how to scroll down the screen yet if it’s at all possible that is.
Anyways after a much longer Auto Tune, approx. 17 minutes and a low Battery warning even though I was seeing I still had over 15 volts of battery, I saw a Red message saying something about being Unable to perform a Auto Tune and to do a manual tune, reason unknown cause I can’t scroll down yet with the Yaapu LuLa script thing. I switched out of Auto Tune mode into Position Hold mode then Back into Auto Tune, just like Everything I’ve read has said to do, I landed in Tune mode and disarmed.
Now “Hoping” that either I managed to save any completed Tunes or by being able to check the Bin logs I can manually make some changes I can’t do either. Nothing was saved and I can’t make out what the Logs are showing.
“Hopefully” someone can look at these logs, which I have No Idea if they are the ones needed or if I posted them correctly, and shed some light on all this for me. It would be Truly Appreciated beyond belief. I’ve been working on this thing off and on for over a year now, so I may have forgotten to do a few needed changes but I would like to finish it so I can get back the 960 Hex I’m building. Being on Disability these things give me something to do with my time, kinda like a purpose now, LOL…
About the basic’s of the 690 Hex:
Frame- Tarrot 690Pro, CubeOrange and carrier board,Dual Here3’s (setup as Best), Mauch 016 PL-2-6s BEC & 002 PL-100 Sensor Board, 2- Tattu 4s 5200 mAh 35c Batteries ( in parallel ) MultiStar Elite 4006 740kv, ARRIS 40amp ESC’s, 13.25 CF prop’s.
Mission Planner version 1.3.75.1 build 1.3.7990.37522 ArduCopter V4.1.1 (01d1aa1e)
I know this was kinda a long read, I just wanted to give as much information as possible. Any and All Help would be Greatly Appreciated and Thank you in advance. Robert
