Help setting up
HI ALL,
i am slowly getting to grips with my APM 2.8 but have 2 queries:-
  1. I have plugged from my receiver the gear channel output to input port 7 (simple mode) on the APM 2.8
    when i calibrate the radio i see PWM values of 1112-1912 i.e. beyond 1800. If i then go into Flight modes i was expecting to see my selected mode switch into simple mode if i use the gear switch. but it doesn’t. Is my interpretation correct.
  2. General query on MAG offsets, i believe the MAG offset range is -150 to + 150 i have the below
MAG_OFS_X = -76
MAG_OFS_Y = -13
MAG_OFS_Z = 1
are these good ?
Ah do i need to go into standard params and set channel 7 to simple if thats possible ?
set channel 7 in standard params to simple mode but no change
Try this
youtube.com/watch?v=30cCs4aHdB0
You won’t see simple mode show up…I do not use ch 5 (Gear) At all
Us Ax’s and mix radio
