I’m trying to have RPM telemetry so I can go to notch filter ‘INS_HNTCH_MODE, 3’
Bi-directional Dshot isn’t working on my FC Speedybeef4v3 freezes I2C if Bidirectional DShot is enabled
I’m confused about what should be the correct parameter settings after reading the docs and forum posts.
It’s possible to use Dshot and still have the single wire telemetry working?
I tried it using both Dshot and ‘normal’ mode but without success, ESC Rpm always 0 in the status page.
Besides parameters listed in the docs ESC Telemetry — Copter documentation should I set anything specific for SERVO_BLH_AUTO, SERVO_BLH_MASK? (anything more?).
I’m getting “ESC: Test FAILED” if I try SERVO_BLH_TEST, but motors are spinning and I can fly the drone in either Dshot or normal/PWM
The wires from FC and ESC board are connected (and there are ‘current’ and ‘telemetry’ wires listed in the connection). It helps if I just test in oscilloscope if there are signals flowing in the telemetry wire?
Telemetry UART is SERIAL5 in this FC stack (SpeedyBeeF4V3), and I have SERIAL5_PROTOCOL, 16
ESC firmware is BLHeli_S
Any tips?
Thanks
actual.param (22.0 KB)
