I have flown my drone twice and both times it has seemingly fallen out of the sky. I have tried to build it as balanced as I can, has a GoPro with brushless gimbal all set up, MinimOSD, FPV and all powered by 3 Cell 25C 5000mah battery. I think the first time it crashed it was a power failsafe but this time I have no idea.
I would really appreciate some help with the log since I really dont know what it is telling apart from the fact that it failed with a crash check-1.
@mboland I agree with your points, but after all - what was the exact reason to crash?
Despite the copter is extremely underpowered but it flied for some time. But then Th.O goes zero. I don’t see a reason for that:
Your voltage jumps up dramatically at the same time as the throttle goes to max, then throttle drops out. I wonder if your speed controllers are set for LIPO batt and have a battery voltage failsafe enabled? This caused me several crashes because the esc battery failsafe would kick in before the FC failsafe, causing the motors to cut in flight. Changing to NIMH disables this.
