Hi, just tried with GV-1 sensor, GV-1 sensor use analog type sensor, so you need some conversion to use with pixhawk. futaba sensor use different polarization of magnet, I think it North. I’ve made sensor with A3114 hall effect sensor, a couple resistor and transistor for reverse the output from sensor. It working now
I have tried using the Align hall effect sensor with the provided magnets and works perfectly with px4 flightstack. I recently moved to Arducopter for the exact same setup and the rpm just refuses to register on the topic “rpm1” when I am checking on Mission Planner. I am using the latest v3.6.9 from your forked repo.
For a board with 6 aux outputs make sure the board pwm count is set to 4 and the relay pin and rpm settings are what is shown in the screenshots in the post at the beginning of this thread.
With all the new features on this release cycle there was getting to be too many builds for each feature. So I consolidated these things and reduced the number of builds to two for 3.6 and one for 3.5. You can pick which one you want to test - all them have the governor.
Also note that in the final version that will be in 3.7-Dev the names of two parameters for the governor will be changed. The H_RSC_GOV_SET becomes H_RSC_HEADSPEED and the governor TC becomes TCGAIN. These changes are not reflected in the ArduHeli 3.6.9 build that has every feature we’ve developed in it.
The descriptions for these settings do not yet appear in any of the ground stations. But they are on the wiki now in the parameter descriptions.
Yes, the 3.6.9 build has four-servo, governor, L1 Nav, virtual flybar acro. Due to the way the servos and swashplate is handled you will have to verify that all your settings for head and cyclic servos are correct before flying. There is a short summary there on the download page that explains the settings.
I am assembling an electric 450 helicopter with a Micro Pix controller, but I have problems with the software governor described here.
For heli version 4.0 an Incorporated a rotor speed governor seems extremely interesting. Not having yet the required RPM sensor I first simulated it with a servo tester on a poorly configured Pixhawk with V4.0.0-rc2 firmware. It works immediately as described here, without arming or safety switch:
(Mission Planner, Flight Data, Status)
Since the servo tester should generate a PWM pulse at 50 to 60 Hz (compatible with analog servos, 3000 to 3600 rpm) 3634 as shown for rpm1 makes sense. If disconnecting the servo tester rpm1 becomes -1.
But the Micro Pix has no AUX pins, but pins equivalent to the MAIN ones on the Pixhawk. PWM1 to PWM5 are connected to four servos and the ESC and work (BRD_PWM_COUNT=5). So one in PWM6/7/8 (or SBUS (unused)) should be defined as input in the code, and have code to implement timing to get rpm.
Not having examined the sources and not having the schematic, I don’t know if this is contemplated. After several trials (changing BRD_PWM_COUNT, RPM_PIN and SERVO6/7/8_FUNCTION) I get always -1 on rpm1 and rpm2 and messages “Cannot attach to pin xx”.
Is it possible to have rpm input on a Micro Pix controller? If so, how?
I wonder the use of these input meaning values: 51 RCIN1 52 RCIN2 53 RCIN3 54 RCIN4 55 RCIN5 56 RCIN6 57 RCIN7 58 RCIN8 59 RCIN9 60 RCIN10 61 RCIN11 62 RCIN12 63 RCIN13 64 RCIN14 65 RCIN15 66 RCIN16
on SERVOxx_FUNCTION: Servo output function
parameters.
What are they meant for?
On Pixhawk schematics sheet 9/12 (Servo Header/S.Bus interface) pins labelled J901-31 to J901-46 (6 AUX) finish in FMU CH6 to CH1, as you say (FMU microprocessor pins PD14, PD13,PE9, PE11, PE13 and PE14).
Pins labelled J901-7 to J901-28 (8 MAIN) finish in IO CH8 to CH1 (IOMCU).
But I have no Micro Pix schematics and cannot find these equivalent connections por Micro PIX PWM1 to PWM8.
