You are almost there…
You need to set SERIALx_PROTOCOL to 28 (scripting).
Then
local port = serial:find_serial(0)
port:begin(115200)
port:set_flow_control(0)
function update()
-- get data, where data is the string you assembled.
port:write(data)
return update, 100 -- 100 is 100ms, adjust it to the needed refresh data
end
return update()
Unfortunately I can’t get this to work.
I have a port open (at least it is not throwing any errors) but no data is being sent.
I tried port:write(5), which means “5” should be sent, right?
local baud_rate = 9600
local port = assert(serial:find_serial(0),“Script unable to find scripting serial port”)
port:begin(baud_rate)
function update()
port:write(5)
return update, 1000
end
return update()
The port is working, tested it with the build in NMEA String when the port is set to 20.
Also, since I can supposedly only send numbers, is data = string.byte(string) the correct way?
Thanks! The string length is 41, and the for loop is working, however there is still no data being received.
Tried different, redundant? syntax just to get anything…
if str ~= nil then
for idx = 1, #str, 1 do
port:write(str:byte(idx))
port:write(string.byte(str,idx))
--gcs:send_text(6, idx)
end
else
gcs:send_text(6, "Script string nil")
end
Unfortunately it isn’t working with local port=serial:find_serial(0) neither.
I checked again, the port is working with the build in NMEA String when the port is set to 20, just not with the script.
My code atm:
local FREQUENCY = 2000
local port = assert(serial:find_serial(0),"Script unable to find serial port")
--local port=serial:find_serial(0)
function update()
if not ahrs:healthy() then
gcs:send_text(6, "Script waiting for AHRS initialization")
return update, FREQUENCY
end
hdg = math.deg(ahrs:get_yaw())
if hdg <0 then
hdg = hdg+360
end
pos = ahrs:get_position()
--gcs:send_text(6, string.format("Lat:%f,Lon:%f,Hdg:%.0f", pos:lat(), pos:lng(), hdg))
--str = string.format("Lat:%f,Lon:%f,Hdg:%.0f", pos:lat(), pos:lng(), hdg)
str = string.format("%f%f%.0f", pos:lat(), pos:lng(), hdg)
gcs:send_text(6, "Script string: " .. str)
gcs:send_text(6, "Script string length: " .. #str)
if str ~= nil then
port:write(string.byte(str,idx)) --redundant?
gcs:send_text(6, str:byte(idx))
end
else
end
end
return update()
Well, sorry I was drawn into another project and forgot it.
But here are my findings.
I put a FTDI USB/Serial converter to Telemetry port1 on a Orange Cube and connected it to my PC and open the port in a Serial terminal. (speed set to 9600)
Serial1_protocol was set to 28, speed to 9600
Since I tested it inside, I commented out the ahrs ready waiting and entered a false coordinates. (See correct script below).
And it was working just fine, I got the cords and heading in the serial terminal window. (I used SerialTool) So it has to be something with your setup…
function update()
-- if not ahrs:healthy() then
-- gcs:send_text(6, "Script waiting for AHRS initialization")
-- return update, FREQUENCY
-- end
if hdg <0 then
hdg = hdg+360
end
-- pos = ahrs:get_position()
-- str = string.format("%f%f%.0f", pos:lat(), pos:lng(), hdg)
str = string.format("14.66526 35.7762 %.0f", hdg)
if str ~= nil then
end
else
end
end
return update()
This is my not existing knowledge about serial connections coming back to me…
What is the correct settings in Serial Tool to receive data?
Do both RX and TX ports need to be open? When I try to open the port in serial tool, the one on the drone cannot be opened and vice versa, because only one can be open…?
I used Device Monitoring Studio to just sniff the incoming data for the NMEA String.
I figured it out.
I used Serial 3 (GPS1) on the Pixhawk 2.1 carrier board. (TX and GND pins)
When I switched to Serial 4 (GPS 2) it worked immediately.
We had a similar issue recently - we just switched the ports and it worked.
Thank you regardless for all the support!
