I’ve got some issues because I compiled QT with EGLF support, as a result QGroundControl crashes when I do something that require a new window on top of the main window. I’m trying to compile QT with EGL on X support now to see if it helps to run within X.
If I get it to work I will make a complete write-up so that you can compile yourself!
Thanks very much for this tuto!
In the same time it would be great if you could upload the physical disk image to save some time and troubleshooting.
Thanks in avdance
Guillaume
I ll be using the official 7’’ touchscreen
I did not even hope you could as well make it work with a joystick! Yes, long range wifi for control and telemetry would just be more than very fine…
