Companion PC: Odroid ux4(will be used for networking,mission plan, opencv(camera)) working on linux ubuntu 16.4
Wifi module for odroid
external 3G to wifi modem huawei r207
compatible Cam for object detection
I still couldn’t choose the GPS and COMPASS along with SONAR because of the prices. Below I post some sensors that are quite affordable. will they work seamlessly with pixhawk and ardurover?
I really need to order them ASAP and start working because ı know this project will be definetly very hard for me.
I will also have a 2 axis gimball with 2 servos connecting to pixhawk to stabilize the Camera(I want to install it in 90’ angled position to make it roll and tilt not tilt and pan if possible tho)
this gps şs 1hz and 5v (will it gonna work seamlessly?)
Will this sonar work efortlessly with ardurover?(it is very cheap for collusion avoidance)
I really need to select my components and order them to start the project.
Normally the transmitter and receiver are purchased together…
The most reasonably priced sonar we support is this one. I think it would be good though to move in stages. Get the basics working before moving on to more advanced things.
The list looks ok to me. I can’t really comment on the odroid too much. I’ve used them and they’re on the list of supported companion computers but we don’t have an APSync image for them so you’ll have to do the setup largely on your own… or maybe use Maverick instead of APsync.
I’m not a fan of the sonar really… all the lidar work better even the low-cost benewake tfmini sonar.
Thanks again. I thought lidar would be too hard. Now after your precious recommendation I switch to Lidar.
Companion pc will not interfere with the boat’a mission a lot. But i was thinking if i had Ubuntu 16.04 on odroid while connected to pixhawk 4 via usb, and mission planner works on the Ubuntu if I’m not wrong tho, could it re plan it like a pc? Because i will run a program like TeamViewer incase of Manuel re planing. But mainly goal is to read gps data, use opencv applications for object detection. When detected an object sending a message via internet along with gps coordinates. So i need lots of computing power.
One big issue is the heat. I’m seriously thinking about the water proofing in plastic tapper wares. I’m afraid to cause unwanted electromagnetic field to mess up with RC and gps etc… But i am not sure about how well odroid xu4 will perform in a fully closed air and water tight box.
I also leaned the brushed dc motors get pretty hot. I’m ordering some small round heatsinks that won’t enclose the breathing holes.
Will using a 2.5mm thick copper heat pipe(ish) cause serious interference problems?
Would it make more sense to deploy the pc at the top back of the boat for better cooling and less interference?
I really appreciate your whole help and efforts. This is a great community. This will be my final graduation project.
Re controlling the vehicle from the companion computer, we have some instructions for Copter here. The commands work for Rover as well though.
I wouldn’t worry too much about overheating. I suspect keeping the components dry will be a bigger issue. I use boxco boxes on my boogie board boat.
One thing you might need to be careful about is keeping the odroid away from the GPS because it definitely interferes with the GPS signal. RPI3s produce less interference I think but don’t have as much CPU power.
I’m ordering my parts. For the odroid what kind of tape i should use inside the casing? I will buy this casing for water proofing and EMI proofing case water proof
I just ordered 3dr Telemetry 433mhz in order to control the missions from Ground Control(laptop)
Odroid will only use the gps data from pixhawk and will do it’s own mission via 3G modem.
Can you refer me to documentation or tutorial on how to connect the (motors are brushed)ESC to the autopilot system. boat is 7006 by Double Horse, and acquired as everything else.
I think this will be a separate steering and throttle boat (aka Ackermann steering) so the steering/rudder servo will be connected to the flight controller’s MAIN OUT 1 and the motor ESC will be connected to MAIN OUT 3. It’s written on the wiki though… so…
Thanks. The 7006 lacks rudder and motors are fixed. Will i be making a rudder? (I thought it would be running on skid steering) Thanks for the reply. And is there any detailed export on esc wiring. Thanks
