Hi, when trying to set the mode 20
or GUIDED_NOGPS
using mavros mavsys
, I’m getting FCU: No such mode
. I first thought it was mavros but it seems that is actually sending the command because if I send something wrong it would say MODE: Known modes are: GUIDED_NOGPS AVOID_ADSB THROW BRAKE...
and also other modes like 0
work fine. My FCU type and autopilot are being recognized correctly from mavros (it seems) but the FCU is not accepting the mode.
The command that I’m running is rosrun mavros mavsys mode -c GUIDED_NOGPS
and I’m getting Timed out!
and on the logs of mavros node getting FCU: No such mode
I suspect it is Ardupilot but I want to start the discussion first to see if I’m probably doing something wrong.
Thanks.
Using:
ROS melodic
Mavros: 1.5.0
ArduCopter V4.0.6,
FCU: KakuteF7 00250031 35385109 38333932
ChibiOS: d4fce84e.
