GSoC 2024 wrapping up: Visual Follow Me
8e6bb209de06bb64a3c8dea6108fe4b21d7af63e_2_690x394
Hi everyone! It’s me, Asif Khan . I’m really happy to share with you the final work I’ve done during Google Summer of Code 2024 for project Visual Follow Me .
First and foremost, I want to express my gratitude to my mentors, @rmackay9 and @peterbarker . They’ve been incredibly supportive and helpful throughout this project, and without their guidance, my work wouldn’t be where it is today.
Description:
This project aims to add support in Ardupilot to track objects in a frame and then follow them, where Gimbal-Camera follow is the first step and drone following is the second. The ability to accurately follow and capture moving subjects opens up new opportunities for advanced applications in search and rescue missions, wildlife monitoring, and autonomous delivery systems. Enhanced object tracking capabilities can also improve security and traffic management, providing real-time data and insights.
There are two major part of this project
  1. The Algorithm to track things
  2. A message pipeline to get things working
  3. Pitch and Yaw Rate Controller
Let us first talk about the algorithm
Algorithms i tried and explored in between of this GSoC period
  • YOLO based object tracking with minimum difference of image vectors
  • KCF (Kernelized Correlation Filters)
  • CSRT (Channel and Spatial Reliability Tracking)
YOLO
It was the first algorithm i come up with, YOLO (You Only Look Once) is a real-time object detection algorithm that detects and classifies multiple objects in an image with a single pass through a neural network. It’s known for its speed and accuracy, making it popular for applications requiring fast object detection, such as autonomous vehicles and video surveillance.
Idea is here:
YOLO.drawio
flaws:
  1. Its heavy to take diiferences of NP array all the time
  2. not able to detect special patterns that may or may not be objects those are already trained.
KCF
KCF (Kernelized Correlation Filters) is an object tracking algorithm that uses correlation filters with multi-channel features, leveraging properties of the circulant matrix to make the computation very fast in the Fourier domain. It’s efficient for scenarios with minimal changes in scale or rotation and works well in real-time applications due to its speed. However, KCF is sensitive to occlusions, non-rigid deformations, and scale variations, which can cause it to lose the target.
Pros:
  • Speed: Very fast due to efficient computation in the Fourier domain.
  • Real-time Performance: Suitable for real-time tracking due to its low computational cost.
  • Simple Implementation: Relatively easy to implement and use in practice.
Cons:
  • Sensitivity to Scale and Rotation: Struggles with significant scale changes and rotation.
  • Handling Occlusions: Less robust to occlusions or when the object is partially hidden.
  • Limited Feature Set: Uses basic features which can limit its performance in complex scenarios.
While i was testing KCF i saw sometimes it is not able to catchup with the tracked object when the drone take a little faster maneuvers. So i decided to give a try to CSRT.
CSRT
CSRT (Discriminative Correlation Filter with Channel and Spatial Reliability Tracking) is an advanced object tracking algorithm that improves upon the basic correlation filter approach by adding spatial reliability, which allows it to better handle scale changes and non-rigid objects. It is more robust to occlusions and deformations compared to KCF. However, this comes at the cost of being slower than KCF, making it less suitable for real-time applications where speed is crucial. CSRT offers better accuracy in challenging conditions like occlusions and scale changes.
Pros:
  • Robustness to Occlusions: Better at handling occlusions and partially obscured objects.
  • Improved Accuracy: More accurate in tracking objects with scale variations and non-rigid deformations.
  • Spatial Reliability: Utilizes spatial reliability to improve tracking performance in challenging conditions.
Cons:
  • Speed: Slower compared to KCF due to more complex computations and additional checks.
  • Higher Computational Cost: Requires more processing power, which might be a drawback in real-time applications.
  • Implementation Complexity: More complex to implement compared to KCF, requiring careful tuning of parameters.
While CSRT is a little slow in my case when i tested i saw it does really good in fast maneauvers of drone and object both.
Finally i decided to used CSRT for the purpose, but i am still open to suggestions to try. Thanks in Advance.
2. A Message Pipeline to get things working
There are two types of messages, first is track rectangle and second is track point, both need to be conveyed to our supercool external tracking system so that it knows what need to be tracked. To do this some new and special parameters in Arduopilot helps us forward those messages to Companion computer, those parameters are:
CAMx_TRK_ENABLE - enables or disables the tracking.
CAMx_TRK_SYSID - The mavlink system id of the external tracking system.
CAMx_TRK_COMPID - The mavlink component id of the external tracking system.
The Firmware now compares the parameter’s defined ID’s with the ID’s it found when getting register heartbeats of mavlink devices, if due to some reason those aren’t matching it discards the requests.
The Link here is Actually a network switch similar to this Botblox Nano
download
3. Pitch and Yaw Rate controller
Now we have all the messages and our algorithm, we can use that data to give the gimbal commands to move. The magic here is that for this purpose we dont need any fancy gimbal camera, even the servo gimbals are supported. I used the RATE commands to control the gimbal. The simple workflow is showed in this diagram
c7203043bd9fbba074633630e3e5e3e9970aad1a_2_666x500
PULL requests related to this work are here
TESTINGS
Everything is readily available to test on simulation though the hardware testing will take a little more time i will update the progress here.
For testing the PR with gazebo just take a look at example scripts and a ReadME here
Here is the testing video for the simulation
I am really grateful for the partners who donated hardware for this project, I am currently building it its 70% compeleted. These are the things i got -
Here is the funding proposal
Well thanks for reading the blog this far. I would like to receive more suggestions and insights, If you want something to add let me know by providing your valuable feedback.
ThankYou!
It would be great if you would use the ArduPilot Methodic configurator to configure the vehicle. It would make it easier for others to adapt their vehicles and still get similar results to yours.
Just add you parameters to the “48_guided_operation.param” file.
Does it mean we can flight without GPS and we can know USV’s position?
No it requires a GPS.
No, for that you need GSoC 2024 wrapping up: High Altitude Non-GPS Navigation instead
so as i understand this,
object tracking is used to center the camera on the object, Then mount information along with vehicle position and orientation is used to calculate the position of the object, are those coordinates are sent to the flight controller to follow?
That’s great! I can’t wait for trying.
I have a simple question here, why it’s in position hold when in test video?
Hi Asif,
I read your work. It’s really great. During reading i got to know one small spelling correction. Please find it in the KCF section.
“While i tested KCF i saw it sometimes not able to catchup with the tracked bject when the drone take a little faster manevers. So i decided to give a try to CSRT.”
Regards!
Very Very Thanks For correcting.
I used a Controller to change the drone position so that i can get faster movements to test gimbal response. For the information, drone follow i am still working on, but thats not much hard. cause now we already know where the gimbal is pointing at.
Great work!
What kind of approach are you using for the follow feature?
Yeah thats a good question The thing is to make the things right and simple i am going to use default follow mode. The default follow mode uses sysid to follow another vehicle. I am changing that to use the tracked objects location. Its still in progress.
GOOD NEWS! The follow is also working now, just some little modifications are left, will make a PR soon after initial tests.
@amilcarlucas Very Thanks for the review, i walked through the methodic configurator setup, here is the template file, I actually added the parameters to 13_general_configuration.param , cause mostly the pipeline parameters are working here, other parameters for guided mode are same. I also added the follow parameters to the same.
Here is the methodic configurator file for the gazebo iris model. to setup this on your systems.
GazeboIrisWithTargetFollow.zip (408.5 KB)
Also if you guys need the full parameter list in any case here is that, for almost all people technically the gazebo parameter list will be same for the iris model, here is it.
full_parameter_list.param (32.4 KB)
I corrected many parameters and added it as a ready to use template on ArduPilot Methodic Configurator v0.9.8
Due to some reason the github artifact is not working So, The QgroundControl AppImage (Local build) is here you can make use of it.
To run the current version of the project you can make use of this google-docs. FYI i am testing with @rhys mavproxy module version which integrates all scripts into a mavproxy module so that we can run all these without needing to run scripts manually.
Amazing!
This is what I have been looking for weeks. Will try this asap.
Cheers
Naitik
Nice job!
I am looking for a way to use a camera in Gazebo simulation for image processing and I am using Gazebo harmonic with ROS 2 humble. I tried to install ardupilot-gazebo using this guide, but I didn’t have any pictures either at the ground station or with gstreamer.
@khanasif786 Would you please explain how you used the gazebo image?
Can anyone help me do this?
