I’ve built a new plane, with a new pixhawk loaded with the 3.2 firmware. RX is FrSky X8R, TX is FrSky Taranis+. Telemetry is 3dr radios. In preparation for a maiden flight, I’ve been going through the calibration steps. Compass, radio, accelerometers, flight modes, etc. all configured without a snag. Everything looks good in terms of control surfaces responding to manual control, and the “HUD” in APM Planner2 shows accurate responses to orientation changes. So I started following this guide:
plane.ardupilot.com/wiki/roll-pi … er-tuning/
to get everything tuned up, but in FBWA mode the control surfaces fail to respond to changes in orientation in any direction. I tried to tinker with PID values with no effect.
I’ve repeated the steps to calibrate various things many times with no improvement. I’m at a loss as to what the next steps might be to debug the problem, and my google-fu is failing to find answers. Is my best option to reset everything back to default values and try again, or am I missing something obvious?
I would like to attach a parameter file to show my settings, however the following file extensions have been rejected: param, txt, docx & doc. Any suggestions in this regard are also appreciated.
Best regards,
Blake
