Hi @gast ! I am comparing raw GPS velocity / change in velocity (post processed from the GPS rinex log) vs. the logged yaw angle, logged yaw rate coming from APM data. In case you make a cross correlation between them 0.06-0.16s gives you the best correlation, but the number varies based on the FCC onbord.
